Periodic boundary condition - pipe flow -setting up heat transfer
Old   December 4, 2012, 03:36
Default Periodic boundary condition - pipe flow -setting up heat transfer
Chris Dorer
Explorer is on a distinguished road
Hi there,
i am trying to run a periodic flow of a part of a pipe. I chose the eights part of a pipe and set up the inlet and outlet as translational periodic and the long surfaces as rotational periodic and the curved surface as wall. After i defined the mass flow rate in translational direction and solved the flow and turbulence with the k-w SST model. It worked quite well and the pressure drop in the pipe part is nearly the same as calculated in the empirical model of Pethukov (<1% for Re=37000).
So after solving the flow and turbulence i turned off solution for flow and turbulence and turned on energy for the heat transfer solution.
Now i get the the message:
"turbulent viscosity limited to viscosity ratio of 100000 in 35400 cells"
"divergence detected in amg solver: temperature -> increasing relaxation sweeps!"
"primitive error at node 0: floating point exception"
"error: floating point exception"
"error object: #f"
What can i do now?
thanky guys
Explorer is offline   Reply With Quote
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Pipe Flow Heat Transfer Saima CFX 5 January 30, 2011 16:41
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 08:40
