December 4, 2012, 04:36 |
LES convergence problem in ANSYS/FLUENT 14.0
Ebrahim
Rep Power: 16 |
Dear all,
I want to solve flow field in a complex geometry(respiratory system) Using LES method. I used an LRN k-epsilon converged solution as an initialization for LES. the pressure-velocity coupling is PISO algorithm and the 2nd order implicit method was used for discritizing unsteadiness. however, the solution diverged at the first time step after about 50 iterations. I'm using ANSYS/FLUENT 14.0. I have solved the flow field by fluent 6.3.26 without any problem but since I must include inlet perturbation for my pressure-inlet boundary condition and FLUENT 6.3.26 doesn't have inlet perturbation for pressure-inlet condition, I should use ANSYS/FLUENT 14.0. Does anybody know why ANSYS/FLUENT 14.0 cannot give a converged solution while FLUENT 6.3.26 can do so? Moreover can you help me in solving my problem? helps will be appreciated. Regards, Ebrahim |
convergence, les |
Convergence problem | suthichock | Main CFD Forum | 27 | May 11, 2009 07:05 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 22:18 |
LES convergence problem: | Ning | FLUENT | 2 | March 14, 2007 21:08 |
CONVERGENCE PROBLEM - oil boiler | MM | FLUENT | 1 | February 15, 2007 05:24 |
convergence problem with SIMPLER | NURAY KAYAKOL | Main CFD Forum | 1 | February 24, 1999 13:43 |
