-   -   Do successfully worked MHD module examples exist? (http://www.cfd-online.com/Forums/fluent/110370-do-successfully-worked-mhd-module-examples-exist.html)
Peterpanza December 10, 2012 02:05
I tried to simulate the plasma arc welding process, I found MHD module iperfectly suits my need, but haven't worked out anything yet, all the variables in user defined memory are zeroes.
:confused:
I would be very very grateful if anyone can share a successfully worked MHD module example
nasser January 20, 2013 11:08
:confused:
hi friends
I have the same problem , do you solve it ?
Peterpanza January 20, 2013 21:30
Originally Posted by nasser (Post 402949)
hi friends
yeah,i had ,or i should say I hadn't
cause it just can not solve that kind of problem.:mad:
Now I am trying to solve it in old way with UDF and UDS,luckily,it is a 2-D module.:D
Peterpanza January 20, 2013 21:34
hi friends
well, I mean i need it to work in this way:
put a current in the middle, and it generates a magnetic field,then put the Lorenzo force in the momentum equations as source term.
Maybe it can do that, but I failed to discover how
Yanlong Li January 21, 2013 11:22
Did you use VOF model together?
Peterpanza January 22, 2013 02:47
Sorry pal,i dont need VOF to solve my problem, it is only a single phase problem
nasser January 22, 2013 02:58
hi friends
I think I can use MHD in my model but I dont Know about Accuracy of it.
Peterpanza January 22, 2013 03:13
Originally Posted by nasser (Post 403246)
hi friends
Do you have induced magnetic field in your model?
nasser January 22, 2013 05:32
yes , I induce magnetic field in my model and it worked .
Peterpanza January 22, 2013 06:37
Do you mean you have a existing current,which is intended to induce a magnetic field?
May I know your model in detail?
violin January 26, 2013 12:29
[QUOTE=Peterpanza;4a current to induce a magnetic field !
nasser January 26, 2013 12:38
No , I only have magnetic field . fluent cant model a current to induce a magnetic field .
Peterpanza January 27, 2013 21:25
yeah.....i had spend weeks figured that out. Thx anyway
