December 10, 2012, 12:51 |
Queries on Meshing
Vineeth Shankar
Rep Power: 13 |
Hey,
I am quite new to using Gambit and I having problems with mesh generation for my helical tube. The tutorials suggest many different ways but I havent got a clue when it comes to determining the mesh type, size, interval etc. I have attached the link to a screenshot of my model. Thanks in advance, Vineeth http://tinypic.com/view.php?pic=so0l86&s=6 |
December 11, 2012, 01:30 |
Maxime Perelli
Rep Power: 41 |
cooper should be ok, but I assume you need to split the volume along its axis.
Instead of one helical tube, you will have many successive helical tubes.
In memory of my friend Hervé: CFD engineer & freerider |
December 11, 2012, 05:37 |
Meshing
Vineeth Shankar
Rep Power: 13 |
Thx a lot for replying Max.
Now why do you say that I should split at different volumes? What good will that do? Does this step by step meshing help the system in processing better and faster? I tried to do the Cooper mesh on the whole volume. The system almost locked up. |
December 11, 2012, 06:03 |
Maxime Perelli
Rep Power: 41 |
beacause your volume can be meshed with cooper, but due to its length, I assume gambit won't be able to mesh it on the fly.
But it you give him tiny volumes, then I am pretty sure it will automatically mesh it with cooper. Just give it a try
December 11, 2012, 11:12 |
Meshing errors
Vineeth Shankar
Rep Power: 13 |
Dear Max,
As you suggested, I split the entire volume into 4 smaller volumes. Now, when I try to mesh each one of them errors start to crop up. These are the errors associated with the meshing of each volume 1. independent loops of swept faces on volume 2 had mismatched intervals 2. natural source face for projecting volume 3 could not be found 3. the intervals would force the mesh to cross itself could not be meshed using cooper scheme 4. check the interval assignments for correctness volume 7 One of the volumes[shows 'meshing face 4' and it never ends] take very long to mesh and the process eventually terminates saying not enough memory. Pls help me out.! |
December 12, 2012, 01:10 |
Maxime Perelli
Rep Power: 41 |
may I see how you splited your volume?
December 12, 2012, 04:13 |
Split volumes
Vineeth Shankar
Rep Power: 13 |
I have attached the image of the split volumes.
The new volumes are 5,6 and 7 as indicated. Splitting was done using face split[hope it's all right]. |
December 12, 2012, 04:33 |
Vineeth Shankar
Rep Power: 13 |
December 12, 2012, 04:47 |
#9 |
Maxime Perelli
Rep Power: 41 |
split more
December 12, 2012, 06:14 |
More volumes?
#10 |
Vineeth Shankar
Rep Power: 13 |
But then what about those errors? Do you mean by splitting the volumes further all of the errors will get resolved?
December 12, 2012, 06:33 |
#11 |
Maxime Perelli
Rep Power: 41 |
once you have a small volume (about 1 winding), then try to mesh the voluem. Gambit should assign it automatically as cooper
If not, then enforce cooper scheme, and select one extremity as source (previously meshed with pave for instance)
gambit 2.3, helical, meshing 3d |
Display Modes | |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Meshing locks workbench window. | andy2o | CFX | 0 | February 1, 2008 05:01 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
