Interfacial area density calculation
Old   December 15, 2012, 06:41
Default Interfacial area density calculation
Govindaraju
kmgraju is on a distinguished road
Dear friend
Can you please give the information about inter-facial area density calculation
For example
I have straight pipe which is porous domain of inner radius 10mm and thickness of the wall 3mm
and length of the pipe is 100mm through which fluid flow through it
How to calculate inter-facial area density
I did this way
Inter facial area density= surface area contact/ Volume
surface area= 2*pi*r*h/pi *r^2*h
=2*pi*10*100/ pi*10^2*100
= 2/10 mm^-1
Kindly give your valuable feedback
Thank you
Regards
Govind
kmgraju is offline   Reply With Quote
Define area and depth for drag coefficient calculation for flow over of cylinders engr FLUENT 5 May 26, 2023 05:22
Problem with reference area alfaben STAR-CCM+ 3 April 21, 2020 09:46
Drag Coefficient Calculation antonusklesk Phoenics 1 August 29, 2012 05:07
Help!!!) Magnet flux density vector calculation J.W.Ryu FLUENT 0 November 7, 2002 21:24
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 08:19
