December 19, 2012, 04:56 |
Floating Point Exception in reaction channel
idil tezcan
Rep Power: 13 |
Hello, I'am trying to simulate a highly exothermic reaction mechanism in a microchannel reactor. Solution Initialization gives an error: foating point exception. And I can't proceed to iterations. Is it about the solver parameters or my initial conditions? Anyone can help?
December 19, 2012, 06:55 |
Philipp
Rep Power: 26 |
Hey,
In 100% of the cases this happened to me is was due to a mesh error (negative volume / faces error...). Did you check your mesh?
The skeleton ran out of shampoo in the shower. |
December 19, 2012, 07:00 |
idil tezcan
Rep Power: 13 |
yes I checked the mesh, no negative value for volume or face area. mesh seems normal. Also I checked my rxn and diffusivity udf's they're normal too. What could be the cause of this problem?
December 19, 2012, 07:03 |
Philipp
Rep Power: 26 |
Why don't you start a new project and load the mesh. Maybe set some simple BCs.
Now try to initialize. If this works then switch on all "extras", but one by one. Try to initialize each time.
December 19, 2012, 07:33 |
idil tezcan
Rep Power: 13 |
Actually I assigned the BC's in gambit (velocity in-, pressure out, interface etc.) then read the mesh in fluent and I put initial values to speicific boundries ( superficial velocity etc) in fluent. Is it OK to assign the BC's in Fluent? because it is hard to identify default names fluent gives to different boundaries. by the way I have 2D geometry and 4 different layers in my system (up-to down: coolant-wall-catalyst-channel)
December 19, 2012, 10:09 |
Philipp
Rep Power: 26 |
I am sorry, I allways set the BCs in fluent...
floating point exception, microchannels |
Floating point exception with pimpleDyMFoam | ebah6 | OpenFOAM Running, Solving & CFD | 9 | November 1, 2017 05:58 |
Inlet Velocity Profile BC - Floating Point exception during solution initialization | Janshi | STAR-CCM+ | 4 | March 14, 2012 10:21 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 16:23 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 03:24 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
