-   -   Fluent velocity magnitude contours (http://www.cfd-online.com/Forums/fluent/110754-fluent-velocity-magnitude-contours.html)
Al-Hashimi December 19, 2012 15:26
2 Attachment(s)
when viewing the results of my simulation, i can't seem to be able to view the velocity magnitude contours (they appear completely blue i.e. 0 m/s).
It is right that I have no slip/velocity at wall but the default interior fluid is blue also.
Please why this is happening? Many thanks for your time.
My simulation is: Mixture of water sand,
Material: Water-liquid (density 988, viscosity: 0.001) & sand (density: 1300, viscosity: 0.0011) (I here entered the spcifcations of the slussy not the soil becouse the soil has no viscosity)
Boundary coinditions: Inlet velocity: 7 m/s. wall no slip.
Refernce values: defult.
Soultion intiation: defult.
Osamah Ali
Attachment 17743
Attachment 17744
flotus1 December 21, 2012 09:22
Did you really run only one time step as the first picture suggests?
Al-Hashimi December 21, 2012 09:37
Yes, but what is this mean freind?
flotus1 December 21, 2012 10:28
It means that your solution has only advanced one second (your time step size) in time starting from your initial conditions.
If you really want to run a transient analysis, you will have to run more than one time step.
Otherwise a steady state-analysis would be better.
Al-Hashimi December 21, 2012 10:38
but is this the reason that i have a blue counors? Thank you very much for your reply.
flotus1 December 21, 2012 10:57
Yes it is.
Al-Hashimi December 21, 2012 11:52
1 Attachment(s)
Many Many thanks for the assistant,
I made it as follows;
time steps: 0.6
Number; 30
i think the running time is 0.6x30 = 18 s
Max Iteration: 6.
but no change ...
Thank you again for your kindness
Attachment 17773
flotus1 December 21, 2012 12:38
OK, there is another problem...
If you plot a velocity contour on a no-slip wall, the values must be zero.
Al-Hashimi December 21, 2012 17:45
Many Many Thanks for everything Mr. Alex ... i know that at the wall the vecolcity is 0, the pictures i sent you is for the enternal fluid.
i will try somethings eals which may be helpful and will inform you later.
Again, many many thanks for everything ... i wish you mery christmas ^_^
Al-Hashimi December 23, 2012 03:41
Dear Sirs,
I did everything to get results but I couldn’t … I’m really got tired. Can you please take a look on my model and see if there is a problem. I did it as follows:
The model is sand separator from water by centrifugal force, I want to separate sand with diameter 20 micron and higher.
Mesh Check
Domain Extents:
x-coordinate: min (m) = -3.129762e+000, max (m) = -3.044762e+000
y-coordinate: min (m) = 9.568687e-001, max (m) = 1.069369e+000
z-coordinate: min (m) = -2.000000e-002, max (m) = 5.317000e-001
Model:
Mixture with slip velocity, 2 phases.
Viscous: k-e with standard, standard wall.
Materials:
water h20 from fluent data base and sand which I made it as follows:
First time, i chooses AIR. i deleted the name of AIR, and rename this name by sand. And then, when I hit the Change/Create button, it display the message "... overwrite Air?” And then i click NO. Clicked on sand and change all values such as Density, Viscosity ... then clicked Change/Create button. That is all.</SPAN>
Models:
Primary = water liquid.
Secondary = sand with diameter 0.03mm
Boundary conditions:
Inlet velocity of: 7.37 m/sec
Initiation of solution,
Calculation with run time:
I tried 0.006 for 100 iteration
And 0.6 x 30 for 10 iteration but no result.
The default interior is blue, I.e. 0 velocity at all.
here is my model:
https://docs.google.com/open?id=0B1F...zdGNmJhWXRDRWs
Al-Hashimi December 25, 2012 05:23
Any Answes ...
-mAx- January 3, 2013 02:19
try to run your model first with simple physics.
Incompressible, one phase and steady.
Once you get something reasonable, you can switch to multiphase, and then unsteady.
