Visible Gemometry to view the inside flow countour |
December 21, 2012, 09:20 |
w
Rep Power: 13 |
I have a square box (3D) and I would like to view the flow of gas inside the box . The inlet of the gas is at the bottom of the box with a small square as inlet. What can I do to make only the gas is visible inside the box? |
December 22, 2012, 07:07 |
SSL
Rep Power: 14 |
You can use pathline in display tab. also you can make a surface and show results on the surface.
December 22, 2012, 12:08 |
w
Rep Power: 13 |
Thanks for the reply . The pathline dispay is kind of messy. The gas has different behaviour at different planes, I would like to show it in a full geometry (square box). Any alternative that I can do to make the box invisible and look into the inside gas?
contours, visible |
[DesignModeler] Flow inside the pipe | Saima | ANSYS Meshing & Geometry | 1 | January 14, 2011 10:55 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
