-   -   Problem with Parallel Fluent (http://www.cfd-online.com/Forums/fluent/111132-problem-parallel-fluent.html)
mohamed_ December 28, 2012 07:33
My Environment:
Windows 7 x64
Intel Core i7 2630
8GB Memory
FLUENT 14.5
Parallel FLUENT works well, and runs for say 21 iterations when it suddenly exits and I get this cortex error.
FLUENT create cortexerror.log file:
Parallel FLUENT received fatal signal ()
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
I closed the program and tried again and it runs for only 21 iterations, I retried over and over and every time it stops after 21 iterations.
and I keep getting the same error.
I tried Serial FLUENT but no such error occurred.
so I guess its local to Parallel Fluent>
I Appreciate any help on this problem.
msaeedsadeghi December 28, 2012 11:23
have you used a UDF?
