poor calculation with temparture-dependant specific heat |
December 30, 2012, 03:29 |
Moser
I am trying to simulate the melting process with the method of effective heat capacity, which requires FLUENT to solve energy equations with changing specific heat. I wrote a udf to specify the specific heat. However, it doesn't help. Temperature rising rate is far beyond what it should be.
Then I tried to work with the constant specific heat, and the result was more acceptable, but not precise enough. Could anyone tell me what should I be aware of to improve the iteration stability and precision with temperature-dependent property? Thank you so much! |
January 2, 2013, 08:43 |
Did you consider setting the enthalpy, too? This was a problem in my first simulations with temperature-dependent Cp.
January 3, 2013, 01:32 |
SSL
Yes, You should also decrease energy URF.
temperature dependence |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Integral specific heat | Steve Amphlett | Main CFD Forum | 0 | August 25, 2000 09:51 |
