December 30, 2012, 11:25 |
Under Relaxation Factor Range
Amin
Hi everyone
I'm simulating mass flow distribution in micro-channel manifolds. The solution does not converge unless I change the Momentum Under Relaxation Factor. I read somewhere in this forum that we are not allowed to decrease the Momentum URF less than 0.5 But as I decrease it less than 0.5 the solution converges faster. Is it OK to reduce URF this way? I encountered an other problem too. Although the residuals are less than 1e-04, there is obvious different in mass flow rate in different number of iterations. could you please help me? Regards, Amin |
December 30, 2012, 23:33 |
SSL
Rep Power: 14 |
For Microchannel, first use double precision, second decrease URF of the UDF for wall slip profile. It's easy to converge it. Try more
January 6, 2013, 15:48 |
#3 | |
rasoul b
Rep Power: 15 |
I want to simulate turbulent channel flow with slip B.C (by LES), But the problem doesn't converge, so can you guide me for URF for momentum & pressure? if you have any other comment, please write it. Thanks |
January 7, 2013, 00:09 |
Lucky
Rep Power: 65 |
You shouldn't ever touch the URF if you are doing LES since it is a transient simulation. If anything, you want to increase URF and make it ORF.
a question about relaxation control | doctor evil | Main CFD Forum | 0 | June 4, 2012 03:51 |
Relaxation and convergence | sammi | Phoenics | 0 | March 20, 2008 03:32 |
relaxation parameter | rvndr | Main CFD Forum | 0 | May 5, 2004 12:34 |
Question on adjusting relaxation factor | CFD Rookie | Main CFD Forum | 3 | January 26, 2004 14:37 |
Relaxation factor | Moon | Siemens | 1 | June 13, 2003 11:13 |
