-   -   ask for help about the reversed flow (http://www.cfd-online.com/Forums/fluent/111428-ask-help-about-reversed-flow.html)
yuhehuan January 7, 2013 03:36
1 Attachment(s)
Hi, everyone! I useds Fluent to simulate the airflow in a small domain and the inlet boundary is velocity inlet (0.25m/s), ouflow as the outlet bondary. In the iteration, there are no reversed flow, but at the 12th iteration, reversed flow occured and solution is converged at the 97th step. I am not sure if the soulution can be reliable because of the reversed flow. The inlet is revised from a triangle (0.007m*0.007m*0.007m). I am not sure the reason of the reversed flow. Dose somebody expain my question? Thank you so so much!
Regards!
yuhehuan January 7, 2013 03:38
Inlet is the green surface at the bottom, outlets are the red surfaces at the side.
yuhehuan January 9, 2013 02:28
Does anybody knows? please, many thaks!
Yanlong Li January 9, 2013 06:30
First of all, I think the color of Inlet face is blue, are Blue Green Color Blindness ?
Secondary, The reversed flow is Ok, it is just used to converge.
