January 7, 2013, 21:08 |
Turbulence models for wide range of y+
Dave Christopher
Rep Power: 16 |
I am using Fluent to model the transient blowdown of a pressure vessel. Due to the large changes in the velocities from the beginning to the end, y+ for my current mesh varies from 200 in the beginning to less than 3 at then end, so much of the process has y+ between 5 and 30.
Will any of the turbulence models give reasonable results over the entire range of y+ from 2 to 200? Which model is recommended for this situation? Thanks. |
January 8, 2013, 00:42 |
#2 | |
Lucky
Rep Power: 65 |
stay away from any of the omega based wall models since those are tuned for grids with small y+ everywhere. But more importantly, it is a very bad idea to have y+ in the buffer region (5-30). You need to get out of it. |
January 8, 2013, 03:30 |
Dave Christopher
Rep Power: 16 |
Yes, I realize that I do not want to be in the buffer region. However, if I increase the cell thickness to get a larger y+ later in the calculation when the velocities are lower, y+ in the early part of the calculation will be 1000 or more. Is that a problem?
turbulence model, y+ from 3 to 200 |
Y plus for various turbulence models | taram | CFX | 8 | December 16, 2013 11:44 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
Tutorial 21: Turbulence models | spatialtime | CFX | 4 | April 24, 2009 05:25 |
Are there more FLUENT Turbulence Models? | Travis | FLUENT | 3 | December 30, 2008 01:45 |
Additional turbulence models for FLUENT | Travis | FLUENT | 0 | December 19, 2008 11:58 |
