Moving equipment in large model
Old   January 9, 2013, 08:43
Default Moving equipment in large model
Gerrald Gelderblom
DoubleG is on a distinguished road
Hi all,
I need to model mixing a large tank (a cylinder of r=20m and h=6m) with three or four mixers of two types (d=6m slowly rotating rotors and d=0.5m fast rotating impellers). the axis of the mixers horizontal (while the axis of the tank is vertical).
For this problem I need to model free surface flow, transient effects (homogenization), temperature effects (so the energy equation), non-newtonian behaviour and turbulence effects. I think this makes it a rather complicated problem.
In order to reduce the problem, I'm thinking of an alternative for MRF approach as follows:
First model the impellers in an infinite domain
Draw a cylinder around the impeller and obtain the solution for the velocity at the cylinder surface.
Draw an equal same cylinder in the tank around the impeller
Enforce the velocity profile obtained from the impeller on the surface of this cylinder using UDF's.
What do you think of this solution, or do others have experience with this idea? I am still a beginner in Fluent so before I spend time in working out the idea I want to have some advise on the feasibility.
Thanks in advance,
Gerrald Gelderblom
PS. If somebody has other tips and tricks for tackling such a problem, you are very welcome!
DoubleG is offline   Reply With Quote
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
How to model many small holes in a large domain? Bryan Woods FLUENT 3 February 5, 2009 19:34
problem in large scale model limingtiger Siemens 0 July 30, 2005 03:59
Large Atmospheric Model Rhydar CFX 0 June 28, 2002 03:01
Searching a Software which can model moving objects Hao Yu Main CFD Forum 1 May 15, 2000 09:42
