Forced convection:enforcing thermal no slip condition on a solid-liquid interface
Old   January 10, 2013, 08:52
Post Forced convection:enforcing thermal no slip condition on a solid-liquid interface
Gourav
gourav.dubey is on a distinguished road
Hey!
I am solving a heated plate- liquid cooling problem with pin-fins over the plate. To ensure the energy interaction between the solid and liquid parts, I made interfaces with the coupled option checked. I am able to get acceptable results for velocity(streamline) and pressure. While, in the thermal analysis, I was expecting that the liquid and the solid surface which are in contact will have exactly the same temperature profile, but I could not get. kindly, tell me how do I ensure that. Or, what is the proper way to approach such forced convection problems.
gourav.dubey is offline   Reply With Quote
Old   January 10, 2013, 13:35
dking
dsking is on a distinguished road
Are you saying that you want to have the temperature of the fluid close to the wall equal to the temperature of the wall? In that case, you would have to use an adiabatic BC on the wall. I don't think you want to do that though because you are solving a fin problem :]
Your setup is probably right as is if you have coupled BC'ss on the walls.
dsking is offline   Reply With Quote
convection, pin-fin, thermal no slip
error message cuteapathy CFX 14 March 20, 2012 06:45
Boundary conditions at Fluid Solid interface (CHT) michelle CFX 1 April 21, 2008 04:06
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
