Residuals flow around cylinder
Like Tree1Likes
  • 1 Post By RodriguezFatz
Old   January 10, 2013, 10:49
Default Residuals flow around cylinder
Pedro Ramos
pedroxramos is on a distinguished road
Hello there!
What you think about this residuals for the flow simulation around a cylinder?
Q=0.02 m3/s h=0.10 m diameter of cylinder=48mm
transient and LES turbulence model
http://i45.tinypic.com/352je61.jpg
pedroxramos is offline   Reply With Quote
Old   January 11, 2013, 09:56
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Can you show us the grid?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   January 11, 2013, 10:12
Pedro Ramos
Of course, thanks.
Old   January 11, 2013, 10:27
Philipp
Hey,
i) Is this 2d?
ii) Did you try any other turbulence model / stationary case and got better convergence?
iii) Did you try to improve the grid? It looks like you have several "jumps" in your mesh size... although I wouldn't expect the residuals to behave like this due to these jumps...
Old   January 11, 2013, 10:30
Pedro Ramos
Hello, thanks for your reply!
Do you think that the residuals are too bad?
This is 3d, i show you the plant of the grid.
I'm obligued to use the LES-model...
Only the continuity value is bad don t you think?
Old   January 11, 2013, 10:37
Philipp
I wouldn't really trust a result if "just one" residual looks unusual. Can you localize the point of bad contiunity?
Could you post a picture of what happens during just a few timesteps. I can not really see something in the residual picture.
I guess you did not change fluent's way of normalizing the residuals. You just use the default way, right?
Old   January 11, 2013, 10:43
Pedro Ramos
Ya... i'm new in CFD...
There is a problem wich concerns me... the velocities are too high in the initial section next to channel's bed. Like this contour of shear stress in the bed shows
I defined the mass flow rate in the inlet with the flow (20 l/s).
Thanks for your help!
Old   January 11, 2013, 10:51
Philipp
I meant the residuals. Can you post a picture of the residuals where you can see just a few time steps? I want to see how each time step converges...
Old   January 11, 2013, 10:56
Pedro Ramos
I'm sorry Like this: ?
Old   January 11, 2013, 13:07
Philipp
Great... Is each of the peaks the beginning of a new time step?
Old   January 11, 2013, 13:54
Pedro Ramos
No, sir... I think that each of the peaks represents one iteration. I defined 20 iterations for time-step...
Do you recommend any example or tutorial for the simulation of the turbulent flow around a body (cylinder)?
Thank you, sir.
Old   January 11, 2013, 14:01
Philipp
I don't think you are right. It looks like you have about 10 peaks each 100 iterations, thus 10 iterations per timestep. I guess you did not switch off the convergence critertion. Go to monitors -> residual monitor and set the convergence criterion to "none". You have the default case of "1.0e-3", which means that fluent will stop iterations each time-step, when all residuals are below 1.0e-3. If you switch that off and maybe increase the maxminum number of iterations per time step -> tadaaa.
pedroxramos likes this.
Old   January 11, 2013, 15:41
Pedro Ramos
Thank you for your great advise!
The results improved and, in the other hand, the simulation is too slow now... but i'm patient
I think it is possible improve the residuals. Do you know the meaning of "extrapolate variables?"
Old   January 14, 2013, 02:38
Philipp
Fluent Help says, that "extrapolate variables" uses a Taylor series expansion to estimate an initial guess for the next time step. If it is faster, I don't see any drawback...
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
1 Was FSI for a flow over a cylinder vmlxb6 CFX 17 May 16, 2011 02:29
reference calcultion, flow around a cylinder butch85 Main CFD Forum 3 January 31, 2011 16:10
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 26, 2007 23:26
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
