cavitation
Old   May 17, 2012, 07:39
Post cavitation
saadia
saida is on a distinguished road
Hey,
I am using Fluent to simulate the flow with cavitation
around hydrofoil (naca 0015) using fluent and I'm trying to use a multiphase flow (water liquid and water vapor). I checked fluent's tutorials about cavitation and they said that I should have two inlets (Inlet 1 as liquid and Inlet 2 as vapor) but in Gambit when I defined Inlet 1 and Inlet 2 on the same inlet face boundary, fluent wasn't able to see both inlets and it shows only 1 inlet... what should I do to define a multiphase flow?? and if i want use udf of cavitation to give the source term in equation of Volume Fraction Equation
how i can introduce this udf in fluent ?
saida is offline   Reply With Quote
Old   May 20, 2012, 03:48
ghost82's Avatar
Rick
ghost82 will become famous soon enough
You have to choose the mixture model, setup two phases (liquid and water), and enable cavitation.
In your boundary conditions panel you will have to set the inlet (that is only one) conditions: you will note that you could select mixture, phase-1 and phase-2.
For phase-2 (vapor) you will be able to set a volume fraction at the inlet (if it exists).
For udf:
click Define->User-Defined->functions->interpreted
deselect use contributed ccp and select display assembly listing.
Browse for your source file and click on compile.
If in fluent command window you wont see any error, you can proceed with your simulation.
Daniele
ghost82 is offline   Reply With Quote
Old   May 20, 2012, 08:29
Default naca0015
saadia
Thanks alot!. I used the mixture model
can you gave me the procedure to follow with details because I did not understand if I use the patch method of fluid or no.
Old   May 20, 2012, 13:10
ghost82's Avatar
Rick
You haven't to pach anything. It depends on your case, but usually the inlet has no vapor and cavitation occurs somewhere inside your domain during the simulation.
You can check this example:
http://hpce.iitm.ac.in/website/Manua...f/tg/tut18.pdf
Daniele
Old   May 21, 2012, 06:32
Default pressure
saadia
Tks alot.
I have a problem to calculate the pressure of the inlet and outlet.
can you tell me how I calculate this pressure please..
Old   May 21, 2012, 07:09
ghost82's Avatar
Rick
If you don't know pressure inlet you should know velocity inlet. Pressure outlet should be known..
Old   May 21, 2012, 07:30
saadia
please tell me if is true or no
velocity inlet is the velocity of flow for mixture
then i chose inlet to phase 2 (vapor) and put volume of fraction at 0
pressure outlet is calculated by sum of operating pressure and vaporisation pressure and i put volume of fraction (vapor) at 0
Old   May 21, 2012, 07:37
ghost82's Avatar
Rick
Velocity inlet is the velocity of mixture (100% liquid) entering your domain.
Pressure outlet is the pressure you measure at your outlet.
If you specify operating density 100.000 Pa and at your outlet you have atmospheric pressure, your outlet pressure will be 0 Pa.
Old   May 21, 2012, 08:02
saadia
for outlet;i must put volume of fraction in 0 or no
Old   May 21, 2012, 08:03
ghost82's Avatar
Rick
Cavitation will occour on the hydrofoil so your outlet has to be placed far enough to have 0% vapor fraction.
Old   May 21, 2012, 08:08
saadia
but i have probelem in my calcul.the residual of vf-phase 2(vapor) is not changed.it stabilized at 0
Old   May 21, 2012, 08:34
ghost82's Avatar
Rick
This means that cavitation is not occurring.
What is your inlet velocity?try increasing the velocity
Are your simulation steady or transient?
Old   May 21, 2012, 08:44
saadia
velocity is 6 m/s for
c=200mm
ang =6°
My simulation is in steady state
Old   May 22, 2012, 05:34
saadia
when i change velocity to 10m/s I noticed that there is a change in the structure of the flow but the residuals of vf-pahse 2 remains stable despite that there is a convergence of other parameters
Old   January 14, 2013, 05:59
saadia
Hey,
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
Combining Cavitation and Thermal Effects? akash_max CFX 4 January 19, 2012 14:09
Cavitation Simulation by CFD Liu, L. CFX 2 November 29, 2000 13:50
Cavitation Simulation by CFD Liu, L. Siemens 2 November 1, 2000 21:51
Cavitation Simulation by CFD Liu, L. Main CFD Forum 7 November 1, 2000 21:26
