Home > Forums > FLUENT
velocity profile
Old   January 14, 2013, 08:21
Default velocity profile
Rohit kumar Mittal
rkmittal1108@gmail.com is on a distinguished road
Dear friends,
i am trying to plot the velocity profile for a flowing fluid at cross section of open channel using fluent. I have done modelling as well as meshing. Beside these in fluent, i have switched on gravity, in models, i have chosen volume of fluid model>open channel flow, checked energy equation and used k-epsilon (2 eqn.).
I have given water as primary and air as secondary phases. Besides these all are set as default. Still i am not getting the correct velocity profile. please help me. I got stuck since a long time.
rkmittal1108@gmail.com is offline   Reply With Quote
Old   January 18, 2013, 17:16
Rohit kumar Mittal
Dear friends,
is there no one who is able to help me?
Old   January 19, 2013, 05:31
SSL
msaeedsadeghi is on a distinguished road
It is an easy problem.
Which boundary conditions have you use? There is no need to enable energy equation.
msaeedsadeghi is offline   Reply With Quote
Old   January 19, 2013, 06:29
Rohit kumar Mittal
Sir,
boundary conditions are as follows:
(1)At velocity inlet-
v=0 at inlet
initial gauge pressure= 0
turbulence specification method- Intensity and hydraulic diameter
temperature= 300K
(2)At pressure outlet-
back-flow direction specification method- Normal to boundary
temperature= 300K
checked the open channel in multiphase tab where-
pressure specification method- from neighbouring cell
bottom level i selected which is at outlet side.
(3)Stationary walls-
wall motion- stationary wall
shear condition- no shear
wall roughness- roughness constant= 0.5
roughness height = 0
wall adhesion-
contact angle(air-water)= 90 degree
All remaining conditions are default.
Old   January 19, 2013, 06:55
SSL
in open channels you should use outflow instead of pressure outlet.
Old   January 20, 2013, 09:02
Rohit kumar Mittal
As per your saying, i used outflow instead of pressure outlet.
What is flow rate weighting?
Although i took its value equal to one.
But still i am not getting the correct velocity profile.
Sir, if you have already done it before, kindly mail me the way in which i should proceed at rkmittal1108@gmail.com
I will be very thankful to you.
Old   January 20, 2013, 10:08
SSL
Set it 1 if you have just one outlet. Else you should define fraction of flow that gets out of the domain from each outlet.
Thread Tools
Trackbacks are On
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 24 February 23, 2015 05:33
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 19:09
[boundary condition] logarithmic velocity profile cfdworker FLUENT 2 April 17, 2009 23:36
Prescribed inflow velocity profile - how to? Alan Main CFD Forum 10 October 28, 2005 12:14
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
