Home > Forums > FLUENT
Impeler
Like Tree1Likes
  • 1 Post By amirhabibdoost
Old   January 16, 2013, 16:51
Default Impeler
Heney Anderson
ha947 is on a distinguished road
Hi friends,
I am beginner and I need your help. I am trying to model a 3 blades which rotates in a water tank. I am not sure about MRF and Sliding mesh? what kind of boundary condition should I use? what about interface?
Please help me.
Best wishes
Peter
ha947 is offline   Reply With Quote
Old   January 16, 2013, 17:13
Default Re: Impeler
Amir
amirhabibdoost is on a distinguished road
I think you should explain in more details. But, I can mention some points:
1-In rotating machinery problems may you want to solve rotor-store reactions. In this problems if you would like to solve an unsteady problem, you can apply sliding mesh. Indeed, sliding mesh is suitable for accurate solution in this condition.
According to your brief description, I think you are not involved in moving parts interaction. So, If your tank does not any stationary vanes you can avoid sliding meshes.
2- MRF as well as Mixing plane are other approaches to solve rotor-stator problems. Of course, MRF and mixing plane are employed when you assumed that flow filed is not unsteady.
3- I guess you can use rotating reference frame, at least to start. Of course, it depends on your problem.
Obviously, if you surf in the forum, you can find enough explanations on this issue.
Best,
Amir
jamalf64 likes this.
amirhabibdoost is offline   Reply With Quote
Thread Tools
Trackbacks are On
