November 13, 2017, 04:38 |
Perforated plate
mehdimoradi
Rep Power: 12 |
Hi
in Fluent guide in porous media part an example has been bought that : "Consider a perforated plate which has 25% area open to flow. The pressure drop through the plate is known to be 0.5 times the dynamic head in the plate" my question is: How "0.5" (bold part) was obtained? in other words how we can to obtain this coefficient for different porosity (for example 20% or 10%...)? Thanks |
November 14, 2017, 11:36 |
Jógvan
Rep Power: 12 |
The most typical approach is to use some empirical correlation. Idelchick is a common source of information and you can find a snippet for thin-walled perforated plates here: https://www.design1st.com/Design-Res...atedPlates.pdf .
Perforated plate | franzdrs | Main CFD Forum | 16 | November 12, 2017 05:48 |
Modeling of perforated plate for 3 phase fluidized | Sanyo | FLUENT | 5 | March 27, 2015 11:01 |
perforated plate, flow direction | Benfa | CFX | 10 | August 2, 2013 07:33 |
Need help on perforated plate with less than 2% open area | sosososo1114 | FLUENT | 9 | August 31, 2011 01:33 |
turbulence at a porous jump (perforated plate) | andrew | FLUENT | 1 | May 8, 2004 09:51 |
