how to define bc for a oscillating flow output?
Old   January 24, 2013, 22:55
Default how to define bc for a oscillating flow output?
jiaqi wang
itsqi7 is on a distinguished road
The output is an oscillating one which has large volumn output and then little volumn reversed flow. I defined the oscillating boundary as 'outflow' but it seems an error as 'reversed flow in 4 faces on outflow 6'.
Could anyone told me which type I should define this bc? Thanks.
Itsqi7
itsqi7 is offline   Reply With Quote
Old   January 26, 2013, 02:30
SSL
msaeedsadeghi is on a distinguished road
You should use pressure inlet for both outlet and inlet. For more configuration you should use a DEFINE_PROFILE udf.
msaeedsadeghi is offline   Reply With Quote
Old   January 26, 2013, 03:22
jiaqi wang
Thanks for ur reply. I'll try that.
Old   January 27, 2013, 16:37
jiaqi wang
Hi, Saeed. I tried to use pressure inlet but the warning still happened. I think maybe FLUENT thought there is no fluid beyond the inlet and outlet, so when there is backflow it reports. Can I define, as I suppose, there is infinite fluid at the other sides of inlet and outlet?
My pump structure is as following.
Thanks for ur kind help.
Regards,
itsqi7
Old   January 27, 2013, 23:35
SSL
It's better to add a channel to inlet and outlet, could get a better results.
Old   January 27, 2013, 23:39
jiaqi wang
Thanks. By the way, how could I define that channel?
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
define three phase flow of air-water-sand farnush Main CFD Forum 0 November 25, 2010 15:28
Flow oscillating device, FLUID141/FLUID142... BV Main CFD Forum 0 February 24, 2006 12:57
how to define mass flow rate in CFX-Pre Atit Koonsrisuk CFX 1 February 16, 2005 13:45
Define outlet with varying flow reistance in CFX Coriolius CFX 1 October 29, 2004 17:31
