how to define bc for a oscillating flow output?
The output is an oscillating one which has large volumn output and then little volumn reversed flow. I defined the oscillating boundary as 'outflow' but it seems an error as 'reversed flow in 4 faces on outflow 6'. Could anyone told me which type I should define this bc? Thanks. Itsqi7 |
You should use pressure inlet for both outlet and inlet. For more configuration you should use a DEFINE_PROFILE udf.
1 Attachment(s)
My pump structure is as following. Attachment 18535 Thanks for ur kind help. Regards, itsqi7 |
It's better to add a channel to inlet and outlet, could get a better results.
