Problem with mixing plane for rotor-stator simulation |
September 24, 2013, 10:47 |
Rep Power: 12 |
hey i just joined since i now start working with fluent ,
Basically i want to create a mixxing plane between rotor side and stator side (the mesh used was generated by someone else). For some reasons that person generated three faces for the outlet side of the rotor and one inlet face for the stator side. For mixing planes you need one pair of inlet and outlet (or is there a way to do three outlet faces <-> one inlet face?), therefore i need to create one face out of the three. here comes the problem: i can neither fuse nor merge the 3 faces no matter what eventhough they should be connected at the edges. you can see the faces on the picture. the error tells me that the zones are not matching for merging or the element count is different for fusing. (please explain the solution like i'm five since i just started working with fluent ) http://i.imgur.com/yukwu4e.png?1 http://i.imgur.com/tPpR61k.png?1 cheers edit: ok found the mistake had to put all the different cell zones together...one for stator one for rotor Last edited by Frukk; September 25, 2013 at 06:17. |
Display Modes | |
Total mass flow/flux through a plane problem | nwalters | FLUENT | 1 | December 18, 2010 13:23 |
Air & water mixing problem | praveenkumar | FLUENT | 0 | April 15, 2010 03:14 |
Turbine stage mixing plane calculation | Knut | FLUENT | 0 | December 4, 2007 13:46 |
Mixing Plane | Lee | FLUENT | 0 | August 8, 2003 23:36 |
Urgent help for mixing plane | cherry | FLUENT | 0 | October 11, 2002 05:35 |
