Steady state simulation with transient partilcle tracking
Old   February 7, 2013, 07:52
Default Steady state simulation with transient partilcle tracking
mali28 is on a distinguished road
I am doing multiphase coupled simulation in which the Fluid is solved using steady state approximation and the particles are tracked using lagrangian approach but using transient option in which all the particles are injected at the same time and tracked in time.
When I compare the results of this simulation with the results of steady state simulation in which particles are also tracked as steady, I see a big difference in the two simulation results.
Both simulations should give me similar results but they don't. The difference in the heat and mass transfer between the two phases in both simulations is quite large. Does any one know why is that so?
mali28 is offline   Reply With Quote
Old   February 7, 2013, 13:43
kingjewel1 is on a distinguished road
Interesting. So after you solver your flow in steady state, do you turn on unsteady and solve flow, turbulence and inject particles? Or do you turn off the equations for flow?
kingjewel1 is offline   Reply With Quote
Old   February 7, 2013, 14:25
The solver for continuous phase is steady throughout the simulation but the discrete phase is tracked using lagrangian unsteady particle tracking option, that allows all the injected particles to be tracked in time instead of tracking one-by-one in steady tracking option.
vortex shedding, transient or steady state analysis type? alfonsojurado CFX 0 October 25, 2012 05:33
Steady state > Transient Willem FLUENT 1 June 24, 2008 11:18
steady state simulation timesteps amine CFX 4 March 17, 2008 10:29
Steady state Aeroacoustic simulation Niten Mistry Siemens 5 May 27, 2005 07:02
About the difference between steady and unsteady problems Lisa Main CFD Forum 11 July 5, 2000 14:37
