Home > Forums > FLUENT
more than one thousand runs ...
Old   January 28, 2013, 05:48
Smile more than one thousand runs ...
Mamdouh
mrenergy is on a distinguished road
Hello everybody,
first of all, I'd like to thank all who helped me (even directly or indirectly) to reach this stage of getting results after two months of starting using ANSYS ICEM and FLUENT.
Now ... I have more than one thousand runs ... on FLUENT
36 airfoils
4 values of Re
7 values of AOA
I need to save time, effort, and avoid errors in repeating 1008 runs settings ...
are there any way to put these runs in a loop?
select geometry file ... apply the 4 inlet velocity values ... for each velocity apply the 7 AOAs ... save case and data ... print Cl, Cd, Cm, Cp, and Cf ...
select the next geometry file .......
or I am dreaming?
I hope not to be dreaming ...
thanks in advance
Best Regards for ALL
Mamdouh
mrenergy is offline   Reply With Quote
Old   January 28, 2013, 09:23
Unhappy
Mamdouh
If it is not possible by the way that I expected ... what is the nearest procedure to do that?
Old   January 28, 2013, 11:55
Amir's Avatar
Amir
Amir is on a distinguished road
That's not a dream at all! You can easily achieve that via performing journal files; by using them, you can automate the procedures. (refer to manual for further details).
Bests,
Amir
Amir is offline   Reply With Quote
Old   January 28, 2013, 13:33
Talking
Mamdouh
thanks a lot dear Amir for your reply ... I started reading about the Journal Files ...
but ...
if you give me some remarks regarding to my mentioned case it will be appreciated
thanks for putting my hand on the solution key
Best Regards
Mamdouh
Old   January 28, 2013, 15:34
Amir's Avatar
Amir
but ...
Best Regards
Mamdouh
Dear Mamdouh,
There are 2 procedures to produce a journal file; let the FLUENT write it with its special notations or to use text user interface; in each method, you have to consider journal codes for at least on case then with little programming you can generate your desire journal file.
Bests,
Amir
Old   January 28, 2013, 15:57
Smile
Mamdouh
I greatly appreciate you help dear Amir
I will try ...
Best Regards and Respect
Mamdouh
Thread Tools
Trackbacks are On
