September 13, 2012, 14:57 |
Mean coefficients
Bharat
Rep Power: 14 |
I am simulating unsteady laminar flow over an airfoil for the Reynolds number 70,000 for different AoA. the reason why i am performing this is to check whether the airfoil stall's or not.i am getting convergence in the solution, but my main concerns are coefficients(drag, lift and moment). HERE, i am enabling "data sampling for time statistics" option (DSTS) under iterate window, which according to the description, will give the root mean square of the coefficients (now, i assume that it will converge after sometime and becomes constant, which i assume a constant value for further "n" number of iterations).but that's not the case, even i select the DSTS my coefficient plots are still oscillating, since my main aim is to compare the coefficients with different AoA's). i am posting a plot for Cl for the reference. one more thing, i am using very fine mesh. PLEASE HELP . Bharat |
September 13, 2012, 15:48 |
NormalVector
Rep Power: 15 |
What does the flow field look like? Is that oscillating? There may be some vortex shedding.
September 13, 2012, 22:26 |
Bharat
Rep Power: 14 |
Hey,
Thanks for your kind attention . Certainly, there is vortex shedding in the flow field. here i post you one picture. please have a look. |
September 16, 2012, 04:32 |
Bharat
Rep Power: 14 |
Sir,
I am glad that you've replied. My main concern is to get the mean coefficient value(lift, drag and moment for unsteady laminar flow), which i can compare with turbulent flow. bharat |
April 28, 2014, 11:11 |
Sheng
Rep Power: 14 |
I suppose you have solved the problem already. One easy way is to copy periodic Cl output values to Excel and get a mean value from there, assuming constant time steps.
Calculate aerodynamic coefficients with openfoam using only opensource programs | Xwang | OpenFOAM | 20 | May 20, 2016 11:26 |
A way to optimize the WENO scheme by optimizing the coefficients of linear scheme | moon_light | Main CFD Forum | 1 | November 27, 2012 09:19 |
how to calculate the viscous and inertial resistance coefficients? | omurakbayir | FLUENT | 1 | November 22, 2010 22:36 |
Blottner Coefficients | f_sizer | Main CFD Forum | 0 | August 26, 2010 07:03 |
Computing aerodynamic coefficients on bidimensional sections in 3D problems | Aragon | FLUENT | 0 | July 22, 2009 04:07 |
