December 7, 2007, 12:48 |
PLEASE, WHAT THIS mean Message (Error)
Dear; IF i read my file.msh in 3D from fluent 6.2 this message view, what mean blow message. PLEASE HELP THANK YOU EMAD
Reading "C:\Documents and Settings\Administrator\dd.msh"... 30602 nodes. 5100 mixed wall faces, zone 2. 1200 mixed wall faces, zone 3. 1200 mixed velocity-inlet faces, zone 4. 5100 mixed wall faces, zone 5. 7800 mixed wall faces, zone 6. 7500 mixed wall faces, zone 7. 2400 mixed pressure-outlet faces, zone 8. 300 mixed wall faces, zone 9. Error: no cells in zone, id = 0, ind1 = 1, indn = 0Reading Cells: failed while reading section 12. Clearing partially read grid. Error: Read aborted due to critical error. Error Object: () Error: Error reading "C:\Documents and Settings\Administrator\dd.msh". Error Object: #f |
December 8, 2007, 02:22 |
Re: PLEASE, WHAT THIS mean Message (Error)
Not try to read the mesh file from "C:\Documents and Settings\Administrator\dd.mshcopy" try to read it from C:\> or any other drive this may solve the probelm.
with compliments K.Baker |
January 28, 2013, 15:11 |
Vinothkumar
i meshed a plain wing in gambit with T-grid, the domain was a bullet shaped. When i was tried to read in fluent the following problem has been arrived:
Reading "C:\Users\KSV\Desktop\2\default_id3632.msh"... 4805 nodes. 2430 mixed wall faces, zone 2. 5648 mixed wall faces, zone 3. 164 mixed pressure-outlet faces, zone 4. 1364 mixed velocity-inlet faces, zone 5. Error: no cells in zone, id = 0, ind1 = 1, indn = 0Reading Cells: failed while reading section 12. Clearing partially read grid. Error: Read aborted due to critical error. Error Object: () Error: Error reading "C:\Users\KSV\Desktop\2\default_id3632.msh". Error Object: #f Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () Plz. help me someone on this problem |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
