January 29, 2013, 09:07 |
number of digits
Thomas Hoffmann
Rep Power: 13 |
hey all.
I'm plotting some temperature profiles in CFD post, see attached. Ass seen the plot is very notchy because Fluent only calculates with 3 digits after the comma. Does any of you guys know how to configure fluent to calculate with more than 3 digits after the comma? Thanks Thomas |
January 30, 2013, 07:42 |
Paritosh Vasava
Rep Power: 22 |
If you are making XY-Plot, look in Plot>XY Plot > Axes > Precision.
January 30, 2013, 08:28 |
Thomas Hoffmann
Rep Power: 13 |
Hi.
Is that in CFD-Post? I can't find the buttons you mention.. I've created a Chart where the data source comes from a Line that I've created in the section where I want to see the temperature profile. |
January 30, 2013, 08:55 |
Paritosh Vasava
Rep Power: 22 |
Soory my mistake, I put options for Fluent.
For CFD-Post look in to Chart > X-axis(tab). Uncheck 'Determine the number format automatically' and then you will be able to edit 'Precision'. |
January 30, 2013, 09:00 |
Thomas Hoffmann
Rep Power: 13 |
hmm, I've tried that, see attached.. I think Fluent have only calculated the result with 3 digits. When I increase the precision to 7, it just gives me zeros after the third digit...
Do you know how to configure Fluent to be more precise in the calculation? Thanks |
January 30, 2013, 10:42 |
OJ
Rep Power: 20 |
Maybe, running in double precision may help?
January 30, 2013, 10:46 |
Thomas Hoffmann
Rep Power: 13 |
it actually is with double precision...
January 31, 2013, 05:56 |
Paritosh Vasava
Rep Power: 22 |
Then I think this 'stair step' behaviour is due to the mesh in y-direction. Did you use boundary layer?
Display Modes | |
ParaView: Number of cells/points in mesh and field don't match | Jaggy_Snake | OpenFOAM Bugs | 2 | March 1, 2017 09:06 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
error in parallel run | immortality | OpenFOAM Running, Solving & CFD | 7 | January 1, 2013 13:35 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Setting number of digits after the point using Gam | Miri | FLUENT | 0 | March 21, 2005 06:00 |
