-   -   quick questions about 2D Low Re simulation over thin cambered Airfoils (http://www.cfd-online.com/Forums/fluent/112677-quick-questions-about-2d-low-re-simulation-over-thin-cambered-airfoils.html)
mrenergy February 2, 2013 10:28
1 Attachment(s)
Hello everybody,
I am simulation the Low Re flow (70 000 > Re > 200 000 ... corresponds about 1 > velocity > 3 m/s) over a family of thin 2D airfoils,
camber from 0 to 10
thickness from 0 to 5
AOA from 0 to 12
I started less than two months ago (with your help and support) using ICEM 14.5 and FLUENT 14.5 as a solver, using transition SST model to capture the Laminar Separation Bubble.
I validate well considering Cl, Cd, and Cp compared with the published measurements and Xfoil simulation.
the domain extended from 15 upstream to 25 downstream
wall Y+ always less than unity, except at the leading and trailing edges, about 1.2
Mesh Quality from 0.6 to 0.9 ... 216 630 cells ... 434 180 faces ... 217 550 nodes
I attached the reply script that I used to generate the mesh and some extreme cases coordinates files.
velocity inlet and pressure outlet ... Ti = 0.1 % and Turb. length scale 0.001 m for both.
I have some quick questions listed from the most important for me ...
1- How can I capture the Laminar Separation Bubble? have I use unsteady analysis? multi zones? How?
2- Should I modify the constants for SST model, specially for most thinnest cases (flat plate and circular arcs)?
3- I got low mesh quality for these extremely thin geometries, how can I improve it?
4- I set the Operating Pressure as 101325 Pa at X = -15 (the INLET section) and ... is that true?
5- I set the Refrence Values ... compute from INLET ... and Reference Zone as FLUID (the entire domain boundary) ... any problems?
6- I didn't change the defaults for the solution methods, controls, or the convergence absolute criteria ... accordingly I got convergence after about 300 to 600 iterations for the thick cases and no convergence at all fot thin cases ... What do you see?
thanks a lot for continue reading until this word
ANY KIND OF HELP, EVEN FOR A SINGLE QUESTION, WILL BE GREATLY APPRECIATED
Best Regards and Respect For ALL
Mamdouh
