number of time-step as parameter
Old   February 2, 2013, 13:54
Default number of time-step as parameter
Saba Saeb
saba_saeb is on a distinguished road
Hi all,
Does anybody happen to know how can one set the number of time steps in the transient study in Fluent as a parameter in parameter set provided by Ansys CFX? There is no "p" located beside the number of time steps!
Cheers,
Saba
saba_saeb is offline   Reply With Quote
Old   February 3, 2013, 04:10
SSL
msaeedsadeghi is on a distinguished road
Didn't understand?
In transient you can set number of timesteps, timestep size by constant of variable using a UDF.
msaeedsadeghi is offline   Reply With Quote
Old   February 3, 2013, 12:09
Saba Saeb
Originally Posted by msaeedsadeghi View Post
Didn't understand?
tnx for ur reply, but I haven't got what you really mean!
I am supposed to do a parameter study where the number of time steps is the only parameter which is being changed by the user in each case (suppose i need to run 3 cases where the number of time steps is increased by a factor of 10 in each case, i.e. it starts with 10 and ends with 1000). Although it is possible to change some parameters like the "number of grids" and the "time-step" via the parameter set without changing the whole case in Ansys, but it is not possible to set number of time-steps as a parameter in parameter set since there is no "p" beside that!
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
plot over time fferroni OpenFOAM Post-Processing 7 June 8, 2012 07:56
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
