February 7, 2013, 06:47 |
pressure correction or mesh quality
michel
Rep Power: 13 |
Dear all,
I am trying to simulate laminar flow in micro-cylinders embedded in a rectangular microchannel so I simplified the model with a unit cell which is a square microchannel including a micro-cylinder with an inlet and outlet by apply periodic boundary condition in the inlet and outlet (I used mass-flow rate for inlet boundary condition). The point is when I applied periodic boundary condition in Fluent, an error just appeared before the first iteration calculating solution "divergence detected in AMG solver-pressure correction" . Although I tried to overcome this problem by reducing under relaxation factor and change some parameters in solution control, unfortunately I could not be able to solve it. In the other hand when I want to make periodic region in inlet and outlet in mesh utility, but the coordinate system light yellow prevent to well define it. I suggest maybe it is related to mesh quality and i have to make a finer mesh, do you have any suggestion about the mesh or solving this problem. Any help would be greatly appreciated. Regards Michel |
February 7, 2013, 07:28 |
Mamdouh
Rep Power: 13 |
Hi michel
I think it is not mesh quality related problem ... the convergence happens before the solution at all ... It seems to be a problem in the boundary conditions ... review ALL your boundary conditions CAREFULLY, and check that is physically consistent and acceptable. GOOD LUCK Mamdouh |
February 7, 2013, 10:57 |
michel
Rep Power: 13 |
Dear Mamdouh
Thanks for your reply. I have checked and it seems there is not anything wrong in boundary condition. But when I tried to change to a finer mesh, the solution give me the same error after 2 iteration. Do you think this problem would be solved with a special mesh or you have any idea about it? Regards Michel |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
increasing mesh quality is leading to poor convergence | tippo | CFX | 2 | May 5, 2009 10:55 |
changing the coefficients of pressure correction | Noel | Phoenics | 1 | April 7, 2009 08:54 |
