-   -   how to choose FSI for transient structure>fluid simulation (http://www.cfd-online.com/Forums/fluent/112880-how-choose-fsi-transient-structure-fluid-simulation.html)
itsqi7 February 6, 2013 22:43
I found the default FSI is fluid>structure, but what I want to simulate is reverse. Does anyone have done this before? Hope to get ur advice.
Regards,
itsqi7
delaneyluke February 7, 2013 17:28
FSI is a two way interaction between a fluid and solid.
If you give more details about what you're trying to simulate, we could help you better
itsqi7 February 7, 2013 17:38
1 Attachment(s)
My project is a valveless pump which has a diaphragm driven by a sine force. What I want to get is the relationship of fluid flow and force. So I suppose there are two simulation systems, first is about the deflection of diaphragm to the force and the second is the fluid flow to diaphragm deflection.
Attachment 18854
Thanks,
itsqi7
itsqi7 February 7, 2013 17:40
1 Attachment(s)
Attachment 18855
This is the first simulation. But I cant connect this result as the setup of FLUENT simulation.
stumpy February 21, 2013 16:49
Use System Coupling. See the oscillating plate tutorial in the doc under Workbench > System Coupling.
