Home > Forums > FLUENT
pressure correction or mesh quality
Old   February 7, 2013, 07:47
Default pressure correction or mesh quality
michel
michel2008 is on a distinguished road
Dear all,
I am trying to simulate laminar flow in micro-cylinders embedded in a rectangular microchannel so I simplified the model with a unit cell which is a square microchannel including a micro-cylinder with an inlet and outlet by apply periodic boundary condition in the inlet and outlet (I used mass-flow rate for inlet boundary condition).
The point is when I applied periodic boundary condition in Fluent, an error just appeared before the first iteration calculating solution "divergence detected in AMG solver-pressure correction" . Although I tried to overcome this problem by reducing under relaxation factor and change some parameters in solution control, unfortunately I could not be able to solve it.
In the other hand when I want to make periodic region in inlet and outlet in mesh utility, but the coordinate system light yellow prevent to well define it.
I suggest maybe it is related to mesh quality and i have to make a finer mesh, do you have any suggestion about the mesh or solving this problem.
Any help would be greatly appreciated.
Regards
Michel
michel2008 is offline   Reply With Quote
Old   February 7, 2013, 08:28
Mamdouh
mrenergy is on a distinguished road
Hi michel
I think it is not mesh quality related problem ... the convergence happens before the solution at all ...
It seems to be a problem in the boundary conditions ...
review ALL your boundary conditions CAREFULLY, and check that is physically consistent and acceptable.
GOOD LUCK
Mamdouh
mrenergy is offline   Reply With Quote
Old   February 7, 2013, 11:57
michel
Dear Mamdouh
Thanks for your reply.
I have checked and it seems there is not anything wrong in boundary condition. But when I tried to change to a finer mesh, the solution give me the same error after 2 iteration. Do you think this problem would be solved with a special mesh or you have any idea about it?
Regards
Michel
Thread Tools
Trackbacks are On
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Layers:problem with curvature giulio.topazio OpenFOAM Native Meshers: snappyHexMesh and Others 10 August 22, 2012 09:03
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
changing the coefficients of pressure correction Noel Phoenics 1 April 7, 2009 08:54
