entrance length
Old   February 10, 2012, 04:28
Default entrance length
hamid
hamid1 is on a distinguished road
hi
i have a question, in case of considering a pipe with pressure b.c. do we need to consider the ""entrance length" ?
what about the other type of b.c?
thank u
hamid1 is offline   Reply With Quote
Old   February 10, 2012, 05:47
delaneyluke is on a distinguished road
If by entrance length you mean an extended domain before the pipe inlet, then yes you need to for all types of BC's , unless you have a fully developed profile that you'll use as the inlet BC.
Regards
Luke
delaneyluke is offline   Reply With Quote
Old   February 10, 2012, 06:56
hamid
thanks Luke for the reply
im a bit confused, i have a T shape pipe and I know the pressure in openings of the pipe (the bc), shall i consider the pipe larger than it is to have a fully developed regime, or pressure bc will by default consider all the "normal gradient" zero, so by this assumption of fluent, the flow is fully developed,
for example in case of using velocity inlet bc, one have to consider the le=0.06 Re as length until the flow become fully developed in laminar regime....
Old   February 10, 2013, 06:27
Ben
bf3g10 is on a distinguished road
I, too, am curious about this consideration of the entrance length as I have a similar T pipe configuration.
bf3g10 is offline   Reply With Quote
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 07:22
Turbulent Characteristic Length/Turbulent Length Scale fluentnoob FLUENT 2 July 3, 2009 08:40
entrance length snowshovel Main CFD Forum 1 April 15, 2008 08:46
DPM: Particle Tracking Madhukar FLUENT 1 July 24, 2007 03:51
