Home > Forums > FLUENT
Divergence and High Aspect Ratios
Like Tree7Likes
Old   April 6, 2013, 17:16
victoryv is on a distinguished road
Originally Posted by Far View Post
Because refined mesh is capturing some unsteady flow phenomena which was not being captured in coarse mesh.
I thought the same thing.
I was wondering what value should I be taking for the pressure and velocity? average values?My pressure values are varying from 99200+450.
Also, how do we say it is mesh independent solution? My previous mesh did not have this big oscillation. The pressure was varying from 99010+50.
So, this can be considered mesh independent solution?Also, if my next mesh refinement oscillates more, what mesh I should be taking as final?
victoryv is offline   Reply With Quote
Old   April 7, 2013, 13:55
Ali
Hybrid is on a distinguished road
What are the units of pressure? If in "Pa", then you have to look into youe mesh, solution. Something gone wrong.
Best Regards
Ali
Hybrid is offline   Reply With Quote
Old   April 7, 2013, 14:11
Yes the units are in pascal. Why is it wrong?
Old   April 9, 2013, 15:27
Can someone suggest me ?
Old   April 10, 2013, 11:30
Ali
Looks too big number, whats your boundary conditions at inlet. is there any possibility to share your mesh or case files?
Best Regards
Ali
Old   April 10, 2013, 14:01
Boundary conditions are fine. Sen you a mail.
P.S I am monitoring pressure and velocity values at a point
Old   April 13, 2013, 14:21
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
what are the boundary conditions at inlet and outlet
Far is offline   Reply With Quote
Old   April 14, 2013, 05:38
Far
Sijal
done meshing and solution. Results seem ok and maximum velocity is 70 m/sec
1. Mesh scaled by 0.001 in all directions.
2. Pressure inlet and pressure outlet were used with given boundary conditions
3. Pressure based coupled solver.
4. 2nd order unwind for convection terms
5. pseudo transient and high order term relaxation used
6. Y+ is less than 6 and therefore qualifies for integration to wall approach along with SST turbulence model.
7. Flow is assumed to be incompressible (need confirmation)
Enjoy...
victoryv likes this.
Old   April 14, 2013, 06:19
Far
Sijal
Old   April 14, 2013, 12:54
Hi Far,
Thank you so much. The results seem to be good.
1. Why did you scale the mesh?
2. I have compressible results to compare with. So I am doing compressible flow.
3.What is this "higher order relaxation" you used?
4.My target is y+<1(or ~1). Also what do you mean by " integration to wall approach" ?
5. Also, by how many lengths did you extend the domain?
Old   April 14, 2013, 20:00
Default Mesh
  #51
Far
Sijal
Mesh file https://dl.dropboxusercontent.com/u/68746918/WT.msh
Old   April 14, 2013, 20:09
I am not able to download the file. Also, can you please email me the file or link instead of uploading here and yeah can you please answer the questions I have asked earlier.
Thread Tools
Trackbacks are On
[ANSYS Meshing] Very high aspect ratio zxin ANSYS Meshing & Geometry 12 August 16, 2011 09:49
Divergence detected in AMG solver:species-0 arulmurugan Fluent UDF and Scheme Programming 0 February 15, 2011 05:22
non zero divergence for incompressible flow! Pascal_doran OpenFOAM Running, Solving & CFD 17 September 21, 2010 10:22
multiphase flow, quick divergence of contuinity eq violet FLUENT 7 February 3, 2009 18:54
About divergence for help! xhliu1 CD-adapco 2 April 7, 2005 03:53
