Home > Forums > FLUENT
Removing object from fluid enclosure whilst retaining named ranges of walls
Old   February 14, 2013, 21:25
Default Removing object from fluid enclosure whilst retaining named ranges of walls (DM)
Anton Zhyzhyn
AntonZ44 is on a distinguished road
Hi all,
I am modelling a wheel in a flow. Some parts rotate. Some parts do not. I have a CAD model of the wheel.
In the past I have removed a CAD model from a fluid flow using either:
1) Boolean removal
2) Enclosure then "suppression" of the CAD model
This removal was fine as Fluent determined my object was a boundary in the fluid and let me set it up as *one* wall inside the fluid. But now I need one wall for the stationary parts, another round the rotating parts.
I tried setting up Named Ranges for the boundaries. The problem is that both boolean removal and suppression (of the part) also suppress any associated named ranges.
When I name my "rotating" and "non-rotating" parts, I can't remove them from the fluid without losing the associated named ranges. So then I have no way of specifying that I want two distinct walls for moving/rotating parts.
So the question is - how do I split up my fluid walls based on geometry from my model, when this geometry has necessarily been removed from the fluid?
This must be an easy problem but I've been at it for hours and can't find anything useful online...
Thanks all
Anton :-)
AntonZ44 is offline   Reply With Quote
Old   February 15, 2013, 21:41
Anton Zhyzhyn
This must be a stupid question to you guys who do this every day, but I've genuinely spent probably 10 hours of my life looking for a solution. Any pointers in the right direction?
Cheers
Thread Tools
Trackbacks are On
Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 15:56
Native ParaView Reader Bugs tj22 OpenFOAM Paraview & paraFoam 270 January 4, 2016 12:39
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
BlockMeshmergePatchPairs hjasak OpenFOAM Native Meshers: blockMesh 11 August 15, 2008 07:36
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
