fluent
Old   February 17, 2013, 00:44
Default fluent
Rohit kumar Mittal
rkmittal1108@gmail.com is on a distinguished road
hey guys
i am trying to do a simulation on pipe flow which is partially filled with water and partially with air. I have done modelling as well as meshing. I have used volume of fluid- open channel flow in multiphase model and k-epsilon turbulance model. Mass flow inlet and outflow as outlet i have chosen. Rest i have chosen as default. But still i am not getting exact result. Can anyone help me to get the exact result i.e. the velocity profile.
Here is the attachment of velocity profile for the cross section of pipe flow
File Type: jpg velocity profile across the channel.jpg (47.1 KB, 8 views)
rkmittal1108@gmail.com is offline   Reply With Quote
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Alias problem when starting FLUENT from command line batch_error FLUENT 0 May 24, 2012 08:20
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
