Home > Forums > FLUENT
problem in Fluent
Old   February 18, 2013, 12:02
Default problem in Fluent
tmeysam92
tmeysam92 is on a distinguished road
Hi all,
i meshed my geometry in ICEM CFD. then i exported to Fluent.
now,i want to have different initial velocity for two parts of my geometry.
what should i do?
thanks in advance.
Meysam.
tmeysam92 is offline   Reply With Quote
Old   February 18, 2013, 12:04
tmeysam92
someone told me that i should use below way in Fluent:
adapt-region-mark
solution initialization-patch
is it right?
Old   February 18, 2013, 13:09
Mamdouh
mrenergy is on a distinguished road
I suggest to solve the problem in ICEM not in FLUENT ...
when meshing, give different name for each part and set the boundary conditions you want for each before exporting to FLUENT
also, you can modify the boundary conditions freely for each part in FLUENT
GOOD LUCK
Mamdouh
mrenergy is offline   Reply With Quote
Old   February 18, 2013, 13:28
tmeysam92
GOOD LUCK
Mamdouh
thanks for your reply.
i know that i can use icem cfd for bounday condition and i used it for naming inlet, outlet, wall, etc.
my question is about naming a volume, not a surface or edge.
we always select a face or surface in 3d geometry for naming as boundary condition. how can i do that for volume? should i use "create part" tool for volume? how?
thanks in advance.
Meysam.
Old   February 18, 2013, 13:50
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
In icem cfd , when you click on create new part, look below and choose "blocks", like that will be able to name one block FLUID1 and the other block FLUID2...
Of course this only applies if your mesh is structured
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is online now   Reply With Quote
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
With both methods you will get same result. And ICEM method will give you more problems as you have to define the faces on interface of both fluids as internal. If you want two fluids only for initialization then Fluent method is preferable as it does not changes the thing in general.
Far is offline   Reply With Quote
Old   February 18, 2013, 14:07
tmeysam92
Originally Posted by Far View Post
With both methods you will get same result. And ICEM method will give you more problems as you have to define the faces on interface of both fluids as internal. If you want two fluids only for initialization then Fluent method is preferable as it does not changes the things in general.
thanks for reply.
the method in fluent is easier, but in fluent i should use adapt reging, you know there are three choices for marking a region, hex,cylinder,sphere(look at below picture), now the problem is that my geometry is a nozzle, and its not like those choices.
what should i do?
Old   February 18, 2013, 14:15
diamondx's Avatar
Ghazlani M. Ali
hex means the you will mark the elements included in sort of a "box" defined by xmin and xmax, ymin and ymax, zmin and zmax. It's up to you to see the boundaries of that box. if you flow is along x, then xmin means the position of your inlet, until the xmax you wanted to...
Regards,
Ali
Old   February 18, 2013, 14:24
tmeysam92
if you look at last post, you will see that i am working on nozzle.
i want to simulate flow in and out of the nozzle, so there is a big cylinder around the nozzle, that the volume between nozzle and cylinder is for simulating the flow out of the nozzle.
now i want to have different initial velocity for just inside of the nozzle , now the problem is that i can not chose a hex or sphere or cylinder, becouse of special geometry of the nozzle.
did you get what i mean??
Old   February 18, 2013, 14:27
diamondx's Avatar
Ghazlani M. Ali
i think you can, play with it a little a bit so you can understand how it works, give some random values and hit adapt. then click on manage, and display, you then see the elements that have been adapted
Regards,
Ali
Old   February 18, 2013, 14:32
tmeysam92
thanks for reply.
i tried to use icem cfd for my proble,.
i am using icem cfd interactive method for meshing. so when it opens icem cfd, first of all i have to choose create block that its name should be "CREATED_MATERIAL",
now when i split the block to two parts, then i use create part like you said, and i named two parts fluid1,fluid2.but the first part,"craeted_material" is vanished and the mesh is not good.(look at below pictures).
Old   February 18, 2013, 14:39
diamondx's Avatar
Ghazlani M. Ali
that is just a problem with face association, can you join the project in which you have created those part FLUID1 and FLUID2 let me take a look at it. or just remove face association where the two block meet
Regards,
Ali
Old   February 18, 2013, 14:52
tmeysam92
thank you very much.
file is below.
Old   February 18, 2013, 15:01
diamondx's Avatar
Ghazlani M. Ali
there you go , as i said problem with association
https://dl.dropbox.com/u/35161486/fi...id1-fluid2.zip
Regards,
Ali
Old   February 18, 2013, 15:21
Far
Sijal
Just press mark. With adapt fluent will refine/coarsen mesh.
Old   February 18, 2013, 15:26
tmeysam92
thanks very much.
as i told you, because of using icem cfd interactive mood, when it opens icem cfd, first i have to use "create block", and i should name that "CREATED_MATERIAL".the problem is that after creating two new parts,fluid1 and fluid2, the first part(CREATED_MATERIAL) is deleted.
and when i meshed my geometry, in returning back to ansys meshing, it gives me error(because of deleting CREATED_MATERIAL part).
do you know why it happens??
Old   February 18, 2013, 15:29
diamondx's Avatar
Ghazlani M. Ali
i'm sure you will find your answer here :
http://www.ansys-blog.com/2012/10/04...d-interactive/
Everything is explained well
Regards,
Ali
Old   February 18, 2013, 15:31
tmeysam92
thanks very much for your really helpful answers.
Thread Tools
Trackbacks are On
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
[ICEM] ICEM CFD boundary conditions conversion to Fluent problem kalyangoparaju ANSYS Meshing & Geometry 0 October 31, 2011 00:40
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
