-   -   Heat generation Rate (http://www.cfd-online.com/Forums/fluent/113385-heat-generation-rate.html)
MARIO276 February 19, 2013 00:08
hello, How i can compute heat generation rate w/m3 for wall ?:confused:
delaneyluke February 19, 2013 18:08
What data do you have? W/m3 is heat generated by volume of wall, considering thickness of wall.
Regards
Luke
MARIO276 February 19, 2013 19:01
Data of combustor
1 Attachment(s)
the combustor is cubic and it's dimension is
X= 9 cm (length), Y= 16 cm (height), Z= 16 cm (width).
property of material wall:
Cp= 870 j/kg.k, thermal conductivity= 0.6 w/m.k, density= 2400 kg/m3.
thickness of wall= 5cm.
shk12345 February 20, 2013 09:57
hi
I am not sure but i hope this will help.
Just calculate heat generated by m*cp*(del)T J
1 J = Watt/sec
Multiply by time in which u want to have heat generated.
And divide it by volume.
Hope that works.
Regards
shk
