-   -   3d vof (http://www.cfd-online.com/Forums/fluent/113394-3d-vof.html)
Smaras February 19, 2013 06:03
3d vof
Need help :(
I am getting this problem with the 3D VOF (air jet impinging over water). The simulation is good till 1.4e-2s but after that it gives the following error. The time step size i am using is 1e-6 with 40 time steps. The setting are as follows:
1. Double with SST
2. Surface tension 0.073 n/m
3. inlet velocity 96.672 m/s
4. PISO Scheme with VF(Mod HRIC) Momentum (2nd ord)
5. URF Pressure 0.3 Density 0.5 Body Forces 1 VF 0.5
In 2D for the same thing, i had mass loss problem but i was able to find the solution with the help of few people here.
Would be thankful for your kind reply.
Regards,
Smaras
===>>>>turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 240257 cells
# Divergence detected in AMG solver: x-momentum -> Increasing relaxation sweeps!
Divergence detected in AMG solver: y-momentum
Divergence detected in AMG solver: z-momentum
Divergence detected in AMG solver: vof-1
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 251038 cells
Primitive Error at Node 0: floating point exception
Primitive Error at Node 1: floating point exception
Primitive Error at Node 2: floating point exception
Primitive Error at Node 3: floating point exception
Primitive Error at Node 4: floating point exception
Primitive Error at Node 5: floating point exception<<<<====
Smaras February 19, 2013 06:15
Forgotten the show the geometry. Its the same for 3D case
(PS the line below on left is not axis its nozzle wall)
http://imageshack.us/a/img90/8106/unbenanntgj.th.png
Smaras February 19, 2013 07:58
Any one please i need help on this quickly :(
