-   -   Low Re SST Transition settings (http://www.cfd-online.com/Forums/fluent/113507-low-re-sst-transition-settings.html)
EliShah February 20, 2013 19:04
Hello Everybody,
I am a beginner in CFD
i am trying to simulate the LSB and other coefficients for Low Re 70 000 , using SST transition model , i need help in proper settings ,
my current settings are :
convergence criteria: 1e-4
meshed rotated at -5 for 5 deg AOA
Velocity inlet : at X=1.02 , y=0
Intermittency =0 ,
Turbulence intensity : 0.12 ,
Turbulence viscosity ratio : 2
pressure outlet:
Intermittency =0
my domain is extended from -15 to 25 times the chord
i am using SIMPLE scheme with default settings for relaxation factors
1- how can i capture the LSB ?
2- What do you think about my settings? is it good?
3- what should be the operating conditions at inlet and outlet with rotation of the mesh ?
thanks in advance
Haseeb
EliShah February 22, 2013 12:38
Any Help !!
