February 16, 2020, 11:11 |
Fluid slows down before reaching airfoil
To all,
I am trying to run a 2-D simulation of compressible flow past a cone in ANSYS Fluent. However, the air seems to slow down immediately after the inlet boundary for some reason, and I don't understand why. I've included a picture of the issue, and my settings are as follows: model: realizable k-epsilon, standard wall functions fluid: air, ideal gas boundary conditions: velocity inlet, 375 m/s walls: no slip on the cone, specified shear of 0 on the boundaries Any advice on this would be appreciated! https://imgur.com/a/Qs3FyQ5 |
February 16, 2020, 16:14 |
Issues
The image shows temperature and not velocity, hence, it is little difficult to say whether the flow slows down or not. But there are other settings that imply improper setup. You need to make following changes
1. Use SST instead of . You may also use SA. If you wish to continue with , use ML instead of SWF. 2. Velocity inlet is wrong boundary condition for compressible flows. Use farfield or pressure-inlet or mass flow inlet. Farfield is most optimum.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
fluent |
[ICEM] Hybrid Mesh on 2D airfoil | Jrmy | ANSYS Meshing & Geometry | 2 | August 14, 2014 15:08 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
Fluid structure analysis of 2D airfoil case | ahsan_smme.nust@yahoo.com | OpenFOAM | 0 | April 22, 2014 06:12 |
Fluid Structure Interaction problem for airfoil | vinair39 | OpenFOAM | 0 | February 8, 2011 07:57 |
oscillating airfoil in an inviscid fluid flow | S.T | Main CFD Forum | 6 | December 10, 2007 08:07 |
