February 25, 2013, 04:22 |
C_UDSI_G problem
Rep Power: 14 |
I managed to collect the gradient of a diffusivity through UDS. It's observed that UDS is correct everywhere, but C_UDSI_G is wrong near boundaries even it is no problem within the computional domain. To demonstrate this problem, one simple case with UDF was attached (flntgz4.zip is case file and flntgz5.zip is data file). If you run the case once, you can see the wrong gradient near BC by GUI, which is supposed to be constant 0.021. Anyone can do me a favour and see how to solve it?
February 25, 2013, 15:47 |
#2 | |
I haven't checked your files but I guess the issue is due to the difference between cell and node values specially if you have large cells near boundaries. Bests,
Amir |
February 26, 2013, 11:47 |
Rep Power: 14 |
Thanks, Amir. Well, even I refine the mesh, the value is still wrong. It is probably because the values at boundaries haven't been specified, since the properties are just assigned to cells. Any further suggestion?
March 21, 2020, 14:24 |
mahdi rostami
Rep Power: 6 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
