February 25, 2013, 13:53 |
Transient- Cant Restore previous sessions
Gowrav Shenoy
Rep Power: 13 |
Hi..
I am doing transient analysis in Fluent -14 for the first time, Bcs. of my constraints i am not able to run my analysis continuously for 24 hrs. I need to interrupt.. I am saving all work in case and data files also saving the workbench file.. The problem is - i am not able to restore/resume from where i have stopped previously.. Analysis is Continuing with update only in iteration number but time step from beginning, it again starting from first time step. ( eg. after 4 timestep 80 iterations will get completed if i interrupt and start,, iteration number will be 81 and time step is first only- means it again calculates 4 steps which already calculated..) Prob Details- With 1800k Elements.. Around Thousand time step with 3.3e-3 step size and each of 20 iteration.. i am not initializing again. What could be the mistake from my side? what can be the solution? Kindly Help.. I hope the info i have given is sufficient.. With Thanks Gowrav |
Transient conduction possible in fluent? | jlefevre76 | FLUENT | 2 | February 5, 2013 09:53 |
Laminar gas flow under slight suction - transient works but not steady | audrey | CFX | 1 | September 8, 2011 19:43 |
Transient, initial variables from a previous solution | nakor | FloEFD, FloWorks & FloTHERM | 0 | April 22, 2011 04:34 |
Best practice for transient simulations? | siw | CFX | 5 | October 30, 2010 05:45 |
Transient vs Steady State | Adam | CFX | 1 | April 12, 2007 11:34 |
