March 1, 2013, 12:35 |
Turbine and Dynamic mesh
Marko Milasinovic
Rep Power: 15 |
Hello.
I am working on piston turbine (2D) which is similar to gear pump. The gears are replaced by two pistons which rotates in opposite directions at 500 rpm. I need to obtain flow field inside turbine. Because the region around pistons is deforming I used dynamic mesh for deforming surface. I wrote UDF for rotation moving of pistons. For deforming region I generated mesh using triangles which have size of 1 mm. The inlet pipe and outlet pipe are meshed using quads, size 5 mm. When I start to preview mesh motion after about 8 time steps I have skewness above 0.9. My step size is 1e-5. I have setup smooting and remeshing options and used default values. I have attached some pictures. Can anyone help me. Regards |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
radial turbine blade simulation with dynamic mesh 6dof(fluent) | mamyjooooon | FLUENT | 0 | April 7, 2011 14:28 |
Wind turbine simulation with dynamic mesh. | sushil | FLUENT | 7 | October 28, 2008 00:40 |
Dynamic mesh analysis | Hussein | FLUENT | 0 | February 19, 2007 08:03 |
Dynamic mesh with turbomachinery | Emanuele | FLUENT | 0 | September 7, 2005 09:30 |
