Grid refinement ratio for unstructured mesh
Old   February 28, 2013, 11:19
Default Grid refinement ratio for unstructured mesh
OJ
oj.bulmer will become famous soon enough
I am trying to streamline the mesh independence practices using Grid Convergence Index and Richardson Extrapolation as they are considered the best in practical CFD. (Ref: Roache, P. J. "Perspective: a method for uniform reporting of grid refinement studies." TRANSACTIONS-AMERICAN SOCIETY OF MECHANICAL ENGINEERS JOURNAL OF FLUIDS ENGINEERING 116 (1994): 405-405.)
Now, element sizes for the consecutive meshes should be known to get the grid refinement ratio used in the calculations in this procedure. But since we use unstructured mesh along with the extruded mesh; I am not sure if the value of element local element size (in the important regions of high gradients) is representative of the size for that particular mesh.
Roache suggests the following formula for grid refinement ratio r for unstructured meshes, using their element-counts N_1 and N_2:
r = \left(\frac{N_1}{N_2}\right)^{1/D}
Now, he defines D as Dimensionality. What does it mean and how to calculate it from the fluid domain??
Thanks
OJ
Last edited by oj.bulmer; March 4, 2013 at 10:18. Reason: Correction in formula of r
oj.bulmer is offline   Reply With Quote
Old   March 4, 2013, 04:10
Lightbulb
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
D = 1 for a one-dimensional case.
D = 2 for a two-dimensional case.
D = 3 for a three-dimensional case.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   March 4, 2013, 04:17
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The idea behind it is that if you want cells with half the edge length in a 3D domain, you need 2^3 times as many cells...
flotus1 is offline   Reply With Quote
Old   March 4, 2013, 10:15
François Grégoire
macfly is on a distinguished road
typo in post #1, r formula is r=\left(\frac{N_1}{N_2}\right)^{1/D}
macfly is offline   Reply With Quote
Old   March 4, 2013, 10:18
OJ
macfly, thanks. Corrected.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] Weird snapping outside a refinement region jasimpson89 OpenFOAM Meshing & Mesh Conversion 0 July 29, 2012 20:46
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
pressure eq. "converges" after few time steps maddalena OpenFOAM Running, Solving & CFD 69 July 21, 2011 07:42
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
