February 18, 2013, 09:41 |
periodic flow-solve flow equation
Rep Power: 15 |
Dear all,
I want to simulate a species transport inside periodic pulsatile flow. A friend of mine is using Open Foam and he told me, that he can calculate the flow once and use this solution later. During the rest of the simulation Open Foam is just calculating the species transport, which saves a lot of calculating time. I found that you can choose which equations to solve at Fluent as well (Solution Methods->Equations). But how can I choose to consider a periodic pulsatile solution for the flow (and not a constant flow)? Thanks a million for any help and idea! Lilly |
February 28, 2013, 03:37 |
Rep Power: 15 |
Does anybody have an idea how to solve this?
March 1, 2013, 03:15 |
Rep Power: 15 |
Thank you, Ali!
I mean the velocity is spatially constant at the inlet-face, but it changes with time. After about one second the cycle starts again from the beginning. It's the blood velocity profile inside a coronary vessel which I want to simulate (transient). Thank you for any help and idea! Lilly |
March 1, 2013, 08:50 |
#5 | |
Ghazlani M. Ali
Rep Power: 28 |
for a "transient velocity profile", you will have to use UDF. i guess you are familiar with that ? for an unsteady velocity profile , use this code:
March 4, 2013, 07:10 |
Rep Power: 15 |
Thanks a million for your help and your UDF profile, Ali!
But I meant: is it possible to solve the flow equations for each time step of the cardiac cycle that I am using and use this solutions for the following cardiac cycles to save computing time (since I have to consider about 50 cardiac cycles at my species transport)? Otherwise the flow distribution would have to be calculated again at each time step of the following cardiac cycles... Thank you for any idea! Lilly |
Use advection step and Dispersion step to solve advection diffusion equation | cooljd | Main CFD Forum | 0 | October 15, 2012 15:44 |
non periodic heat tansfer on periodic flow field | tomekk89 | FLUENT | 2 | July 28, 2012 12:06 |
Solve Flow or VOF simultaneously ? | Ramsey | FLUENT | 1 | February 16, 2011 13:16 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
help!!!how to solve multiphas flow combustione | king J | FLUENT | 7 | November 26, 2000 22:43 |
