Home > Forums > FLUENT
Pressure Coefficient on shadow walls
Old   March 5, 2013, 05:27
Default Pressure Coefficient on shadow walls
Roby_1986 is on a distinguished road
Hi everybody,
My domain is made of a building, with solid walls and the air surrounding it (inside and outside). Importing the mesh in fluent, the software has created wall and shadow walls for the building.
Somobody knows how what should I do to calculate Pressure Coefficients on each wall of the building?
I obtain values both on a wall and on its shadow, so I could summ up all the values obtained?Or I should consider just the shadow wall?
Thanks
Roby_1986 is offline   Reply With Quote
Old   March 14, 2013, 10:18
delaneyluke is on a distinguished road
A shadow wall occurs when you have an internal wall with a fluid mesh on either side of the wall.
Generally the results on a wall will be the same as that on the shadow. So when post-processing you can use either of the two, it should be the same.
Regards
Luke
delaneyluke is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 10 February 5, 2014 12:17
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 16:00
Simulation of a single bubble with a VOF-method Suzzn CFX 18 October 2, 2009 04:18
XY plotting pressure coefficient on the wall Yucel Ozmen FLUENT 2 January 16, 2006 22:36
Problem in Result of the pressure coefficient Ken Choi Main CFD Forum 2 March 15, 1999 05:15
