convergence
Old   March 5, 2013, 07:35
Default convergence
ohad liron gazit
lirongaz is on a distinguished road
hi! i'm new here in the forum and new in the fluent.
i made a case which suppuosed to be based on the case of ahmed body, acoording tutorials, and the results don't converge after 600 iterations.
i wonder what could be the problem. i guess it's not in the mesh, because i followed the tutorials.
could it be the models i used? i chose the K-epsilon realizable non eq.
what else can affect the convergence?
lirongaz is offline   Reply With Quote
Old   March 5, 2013, 07:44
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
There can be many reasons. Please post a picture of the residuals.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   March 5, 2013, 09:02
ohad liron gazit
here are my residuals...
does it help?
Old   March 5, 2013, 09:40
Philipp
They look fine. You should let it running until residuals are lower.
Old   March 5, 2013, 11:37
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
look at the solution method, the tutorials work in first order, yours are second order i guess.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 6, 2013, 07:39
OJ
oj.bulmer will become famous soon enough
You should monitor the parameters of interest at different points, to make sure it is converged, rather than relying on the progress of the residuals.
oj.bulmer is offline   Reply With Quote
convergence
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 14:20
