Dynamic mesh
Old   March 7, 2013, 05:18
Default Dynamic mesh
Arty is on a distinguished road
I am not really a Fluent whiz, so, here is a question:
Is it ok to make a two-way FSI considering a gas compressor blade using Fluid Flow (Fluent) with Dynamic Mesh turned off or the Fsi doesn't make sence in this case?
I did not use dynamic mesh because otherwise I got messages about negative cell volume and I'm tired trying to make it positive)).
Arty is offline   Reply With Quote
Old   March 7, 2013, 07:15
Anton Lyaskin
A_Lyaskin is on a distinguished road
When you turn off dynamic mesh, you get one-way FSI instead of two-way. So it's better to find the reason of negative cell volume messages. Usually it means that your time step is too big. Or you've messed something in dynamic mesh methods...
A_Lyaskin is offline   Reply With Quote
Old   March 7, 2013, 09:48
Cristiano
fluent87 is on a distinguished road
try to change the layer dimension (from dynamic mesh menu) or the mesh cell dimension . Usually there is a problem in the dynamic mesh direction. Tray to create a mesh for layer (on a plane e extrude for alla lenght).
fluent87 is offline   Reply With Quote
Old   March 7, 2013, 22:01
Thanks for the replies guys.
I think that the time step is small enough, and so I tried different Mesh Methods, but there is a new problem:
Couldn't intersect threads 7 and 8.
Can you tell what's this about?
By the way, I didn't really get anything about layer dimension or the mesh cell dimension, or a mesh for layer. I looked through the fluent tabs, but didn't find anything about, so could you tell me what you meant?
2-way fsi, dynamic mesh, fluent, negative cell volume
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 10:42
Incylinder dynamic mesh with volumetric reaction mas FLUENT 4 May 3, 2012 10:22
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
